next step after create Truth Table to make 7 segment LED ..#2
theGOATEST
Joined Nov 7, 2024
Design a circuit to take binary inputs and display a number on the counter. The counter needs to display the number 2 followed by 4 to indicate the current year the coursework was done (i.e., 2024). Then, this will be followed by your unique OUC student ID number (person number). This means that everybody will have a unique problem to solve as no two students have the same student number. As an example, if your student number is 123456, your counter needs to display 24123456.
I have done the the top part, I am confused with this bottom one!
Each of the wires on the counter below corresponds to a segment in the counter. If the wires on the counter are labelled a to g from left to right, the wires relate to the segments as follows:
Provide a brief description of how you will modify your circuit to display the number sequence in binary, using an 8-bit binary number representation for each number. Try and think how you will make the modifications using as few gates as possible. (NOTE: only a brief textual description is required, you do not need to draw the actual logic circuit.)
liaifat85
Joined Sep 12, 2023
200
Each digit (2, 4, 1, 2, 3, 4, 5, 6) will be represented in 8-bit binary:
  • 2 → 00000010
  • 4 → 00000100
  • 1 → 00000001
  • 3 → 00000011
  • 5 → 00000101
  • 6 → 00000110
Use a counter (e.g., a 3-bit or 4-bit binary counter) to step through the digits in sequence.
theGOATEST
Joined Nov 7, 2024
  • 2 → 00000010
  • 4 → 00000100
  • 1 → 00000001
  • 3 → 00000011
  • 5 → 00000101
  • 6 → 00000110
I am using digital works, and if I am to do that does it mean if I want to display 24 I will append, 00000010 to 00000100 and step through them?
theGOATEST
Joined Nov 7, 2024
For example, I have this. A sequencer has 00, and B has 01. It's displaying 21. How can I modify this to display an 8 bit representation of those numbers?
