Oh, I see. Alright it looks like I am going to use the 40192 and then just get the 4511 to decode it for the 7 segment. Thanks again guys! I am probably going to order all of my components from mouser today and hopefully have it soon!That would be your call. It could use the up and down inputs to count and display the selected gear, or just run the four output lines from the 40192 to a 4511.
Alright I found the datasheet:In the photo you posted, there is a circle in the right hand corner of the top of the relay IC. See it? That's above Pin 1.
Find the datasheet for your relays; the datasheet will tell you what the internal schematic is. It'll be duck soup from there
Nevermind guys, I figured it out. I ordered the wrong package size. I ordered the cd4081BM... The M suffix is the small chip... I reordered the cd4081BE which is the size I need.Alright, well I got all the stuff today.
The cd4081 IC chip is extremely small. Much smaller than the others. Is there some kind of socket this can fit into to make it the same size pins as the others?
