The LED strip lights below will be connected to a motorcycle and used as tail lights. The stock wiring is present and the LED strips run of
12v.
http://www.ebay.co.uk/itm/321810192393?clk_rvr_id=1313208706955&rmvSB=true
Motorcycle battery = 12v, 8.6amp
The wiring for brake lights on the motorcycle consist of 3 wires - Green, Black, Green and yellow
Wires for LED strip lights - red wire, black wire
pretty sure these LED are plug and play, was also mentioned in the product description. Plan was to connect the LED red and blacks together then simply connect those to the wiring.
Just need your help on which wires go where please, Don't want to play around taking risks with electricity..We've met before on a number of occasions![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
12v.
