Hey. Have anyone used new raspberry PI camera - https://www.raspberrypi.org/products/raspberry-pi-high-quality-camera/
I need to use a camera for my raspberry PI application and need a clear good quality image from about 0.5m-1m distance.
The camera needs to capture what is inside a box which is ( 0.5m - 1m) distance from the camera. The camera will be standing directly above the box. The items inside the box will not be very tiny but could be as small as 1/2 raspberry PI size board. I do not need to see the numbers or anything just need to be able to get a clear enough picture to recognise whats there.
I do not have anything in common with photography but could someone suggest me whether this camera will be capable of achieving what I need since I do not want to throw away $70. Also, what lens would you suggest there are 6mm and 16mm options.
Appreciate any advice!
