Hi folks. My project revolves around a design for budget e-bikes to sell to the locals here in the Philippines. So far, I think I've solved that and can make complete e-bikes for about $200 (sell for around $250ish). Understanding that the most current pulled from the battery's capacity is starting from a dead stop, I have an idea where I could use a small bank of 9x lithium-ion 4v/1100F supercapacitors to handle this. I think this could add to the battery life. The goal is to get as close to 20 miles on a 36v/4ah li-ion battery system. The supercapacitor bank of 9 caps are calculated to hold 1.22 amp/hour (in theory). These new lithium-ion supercapacitors (1100F) are actually smaller than 18650 cells, charge in a matter of seconds, and hold 1200mah each!
Anyways, I need some help. Correct me from here on out...
I'm imagining, at a dead stop, a button on the handle bars, when pushed, will switch on the NO cap bank and switch off the NC battery. When reaching optimal/efficient motor RPMs, release the button and the cap bank is disconnected, the battery is re-connected and the charger connects but only when there is detectable motor RPMs and zero accelerator (brakes will have nothing to do with this). A motor controller will be double lugged at the inputs with the battery leads and cap bank leads; and, the cap charger will be fed from the motor leads replaced with large current carrying conductors (#12awg) to enable the cap bank to be quickly and easily recharged with a 20amp charger module when slowing down/coasting. I assume I'll need a diode here and there to keep the current from flowing in the wrong places?
Of course, this all exceeds my original plan to stay in a budget; but actually, the extra stuff will only cost maybe another $100, I think.
Sadly, all I can think of is using little switching/etc modules available online to do all this fancy switching. Maybe it's too much action and not realistic? Is this a good time to learn how to use an Arduino? Are the Battery and capacitor likely to blow up?
Cheers...
Cheers...
