EDIT: After finally finishing this post, its probably the longest I have ever posted on a forum. If any of you fall asleep during my reading, Sorry!!
First of all I want to say this place . Ive spent the last 2 hours reading and reading. I live in California and do lots of fishing. About a month ago we were night fishing for cats off one of the local docks and were talking to a guy about green fishing lights. He said they are great for catching bait (minnows) and for bringing in some fish as well. I started doing some research and found a few companies that make them. After seeing how much these things cost, I figured I would try and see if I could make one cheaper. They want to charge like $175 for a 24" inch light and about $250 for a 48" light....theres even a guy selling plans for $30 that tells you where to buy everything...If I were to build a 24" light, it would cost about $113,a 48" about $137. Also add in the cost of a deep cycle battery as well....they arent cheap and heavy to lug fishing. Heres what they are.....a green flor bulb, some sched 40 pvc and a 12v dc converter......not much to them.
So Im sitting here on the web trying to find some more info on these and go to take some notes and the pen lights up Green......hmm, wonder if i can use some LEDs...longer life, possibly brighter, might be able to use a small battery...Im starting to like this idea more and more. Ill also let it be known Im not well educated in electrical and circutry so bear with me here.
I think the first light Im going to build is going to be about 24" long. Im going to be using 3" clear sched 40 for the housing ( impact resistant) and white sched 40 for endcaps. This should give me plenty of room on the inside to make some sort of light bar. Heres where the fun begins
1. Ive been looking at different sites and have found lots of info on Green leds. Im debating on what size and style. I think I have narrowed it down to these...
http://buy-leds-online.com/599.html
The 100° 5mm flat top in pure green OR
http://buy-leds-online.com/Piranha40.html
40° Pure green.
Can anyone recommend any other bulb options I might want to look into? What about drivers? They needed with this many LED's?
3. Ive seen some of these LEDs are diffused. I would like the light to travel as far out from the housing as possible, but at the same time I want the light to be even. Should I Leave everything crystal clear or should I scotch brite the inside of the pvc? Heres what the green 12v flor tube looks like submerged. Will it be anything like this??
I was browsing another post on here and found a light saber by hyperdynelabs. This looks exactly what I would like to accomplish.
Powering this thing:
One of my buddies used to own a battery company. Well I ended up with about 200 Laptop and drill batteries when everything shut down. I have everything from 18v cordless drill batteries to 9v laptop batteries..Li-Ion and Ni-MH.....
Whats the easiest way to wire all of these together. Series/Parallel with resistors? Found this on a forum.
http://led.linear1.org/led.wiz
How accurate is it? It would only let me use a max of 32 LEDs?
So lets say I made a light with 32 of the 100° 5mm flat top LEDs. Voltage is from 3.5 to 4v and FWD current is 20mA. To light this thing up, Lets say I would be using 2 18v drill batteries wired in parallel with a total of 6000mah. The calculator says it draws current of 160ma from the source..how do I find out how long the 2 batteries will power the light for?
Now say I wanted to power this with 2 11 volt laptop batteries? Is it still going to be as bright? Or do I have to stick with the 2 18 volt drill batteries. I can go down in power w/o messing anything up, just cant go up in power to say 22v batteries???
3. With 24" of clear schedule 40 Im probably going to Use 11 of these per column @ 2" spacing. 5 columns for a total of 55 LEDs. Is this overdoing it? How much heat is going to be possibly generated? Sched 40 is good up to 140°, but this is going to be submergered in cool water so some of the heat should be dissapated.....hopefully. How do I even attach these too the center light bar in the housing itself.....
Im all ears at this point. thanks guys
Brian
40° Pure green.
Brian
