MODERATOR NOTE: Please use informative subjects on posts, it helps people to help you. The subject has been changed to be more specific.
Hi Peeps,
I have recently been asked to input *.nc files to various machines at work. After the initial learning curve, I am now aware of irritating abnormalities in some of the files I receive. So after a little exploration I thought I could make a little app to fix some of the abnormalities.
Sorting the text in the files shouldn't be too much of a problem, but displaying the drives and files in the way that I want is proving to be more of a challenge.
The Info:
Windows 10
Vis Studio 2022 (just installed)
Building for .NET7
1. I am trying to get the filenames only of any folder selected in the lefthand TreeView to appear in the next pane (which is a ListView).
2. I don't want any files shown in TreeView, just folders.
Any comments or assistance would be appreciated, and I look forward to your replies.
Regards
GB
Hi Peeps,
The Info:
Windows 10
Building for .NET7
VS2022 .net:
Imports System.IO 'Allows operations on Files
Imports DSTV_Wiz_3.My
Public Class Main
Public mypath As String
Public MyFiles As String
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Me.Text = Settings.AppName & " - " & Settings.AppVersion ' Sets the name & version at top of window
ListView1.View = View.Details 'Set View of ListView
' Add ListView Columns With Specified Width
ListView1.Columns.Add("File Name", 150, HorizontalAlignment.Left)
ListView1.Columns.Add("File Type", 80, HorizontalAlignment.Left)
ListView1.Columns.Add("Date Modified", 150, HorizontalAlignment.Left)
TreeView1.Nodes.Clear()
'Loop For Get Drives
For Each myDrives As System.IO.DriveInfo In System.IO.DriveInfo.GetDrives()
Dim myDrivesNode As TreeNode = TreeView1.Nodes.Add(myDrives.Name)
'Adding "Expand" string is use for Add Expand "[+]" option on Drives
myDrivesNode.Nodes.Add("Expand")
Next
End Sub
Private Sub Main_Loaded(sender As Object, e As RoutedEventArgs, TreeView1 As TreeView)
Dim trvNode As New TreeViewNode
For Each drive As DriveInfo In DriveInfo.GetDrives()
trvNode.Tag = drive
trvNode.Header = drive.ToString()
' The placeholder string below is never shown,
' because the node begins in collapsed state.
TreeView1.Nodes.Add("*")
'Dim value = TreeView1.Nodes.Add(trvNode.Tag)
'AddHandler trvNode.Expanded, AddressOf Node_Expanded
Next
End Sub
Private Sub OpenToolStripMenuItem_Click(sender As Object, e As EventArgs) Handles OpenToolStripMenuItem.Click
'Open File and display
Dim openFileDialog1 As New OpenFileDialog()
openFileDialog1.Filter = "NC files (*.nc)|*.nc|NC1 files (*.nc1)|*.nc1"
openFileDialog1.FilterIndex = 1
openFileDialog1.RestoreDirectory = True
Try
If openFileDialog1.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
Dim fileName As String = Path.GetFileName(openFileDialog1.FileName)
Dim filePath As String = openFileDialog1.FileName
'MessageBox.Show(fileName & " - " & filePath)
If (fileName IsNot Nothing) Then
Dim reader = My.Computer.FileSystem.ReadAllText(filePath)
TextBox1.Text = "" ' Clear Richtextbox before writing new file
TextBox1.Text = reader
End If
End If
Catch Ex As Exception
MessageBox.Show("Cannot read file from disk. Original error: " & Ex.Message)
End Try
End Sub
Private Sub TreeView1_BeforeExpand(sender As Object, e As TreeViewCancelEventArgs) Handles TreeView1.BeforeExpand
Dim MyExistNode As TreeNode = e.Node
'Clear TreeNode
MyExistNode.Nodes.Clear()
Try
'Loop For Get Folders
mypath = MyExistNode.FullPath
For Each myFolders As String In System.IO.Directory.GetDirectories(mypath)
Dim FldrNode As TreeNode = MyExistNode.Nodes.Add(System.IO.Path.GetFileName(myFolders))
'Here, Expand is use for add Expanding option "[+]" on folder
FldrNode.Nodes.Add("Expand")
Next
Catch ex As Exception
End Try
End Sub
Private Sub TreeView1_AfterSelect(sender As Object, e As TreeViewEventArgs) Handles TreeView1.AfterSelect
'Loop For Get Files
For Each MyFiles As String In System.IO.Directory.GetFiles(mypath)
Dim FileNode As ListViewItem = ListView1.Items.Add(MyFiles)
Dim MySelectedNode As TreeNode = e.Node
Next
End Sub
Private Sub ListView1_SelectedIndexChanged(sender As Object, e As EventArgs) Handles ListView1.SelectedIndexChanged
Dim ListViewItem item1 As New ListViewItem()
item1 = ListView1.SelectedItems[0].Tag
If (MySelectedFileName IsNot Nothing) Then
Dim reader = My.Computer.FileSystem.ReadAllText(MySelectedFileName)
End If
End Sub
End Class
Regards
GB
