Need to keep a relay latched for 2-3 seconds without power supply
tunafish24
Joined Oct 21, 2011
28
I'm new to circuits and building a simple prototype to keep the relay latched for a couple of seconds after power is removed - so essentially the power to relay acts as the Input signal. This means I have to store energy in a capacitor (to keep the relay latched) and possibly use resistor as well to control current in the circuit. Can you guys please help me figure out C and R values and how the components would link (C would be in parallel with the Relay but not sure about R)?
Important things for me are:
1. Relay should latch as soon as 12V power is applied
2. Capacitor should charge within 500-700ms and be able to keep relay latched for 2-3 seconds.
3. Since I have to charge capacitor quickly, I need to factor in-rush current so as not to damage power supply.
Would really appreciate if you can share the calculations as well, so I can try with different relays and capacitors etc.
The relay i have is Songle 12V (SRD-12VDC-SL-C), Datasheet: http://www.songlerelay.com/Public/Uploads/20161104/581c81ac16e36.pdf
38,806
To keep the relay energized for 2-3 seconds would likely require a little less than 1 time-constant, depending upon the actual drop-out voltage of the relay.
1 time-constant is a capacitance of 3s / 400Ω = 7.5mF(7,500uF).
You could start with 5mF and see how that works
To charge to 98% of 12V within 500ms would take 4 time-constants, which gives a charging resistance of (0.5s /4 ) / 5mF = 25Ω.
The maximum charging current is then 12V / 25Ω = 480mA.
AnalogKid
Joined Aug 1, 2013
12,272
Does that mean that the one or both leads of the supply are physically removed (unplugged or with a switch), of that the 12 V source goes to 0 V. If the latter, you will need to add a diode in series with the supply so its output circuits do not add a discharge path for the capacitor.
ak
AnalogKid
Joined Aug 1, 2013
12,272
Updated the design, also added an Led so I can tell the relay is energized. Looks good?
Not really.
First, the LED tells you if there is enough energy left in the cap to power an LED. Without using a second set of relay contacts, a simple LED cannot give you exact relay status. If staying lit for a few seconds after the relay has dropped out is ok, then ok.
Second, the LED is drawing energy from the hold-up cap, starting at 16 mA. That's over 50% of the current being drawn by the relay coil, and will shorten significantly the hold-up time.
ak
tunafish24
Joined Oct 21, 2011
28
I have one of those relays, 5mF will get you 3 seconds.
Perfect!
Good point, I thought the energy usage would be minimal...I'll remove the led then. Does the rest look good?
PS. I noticed that you replied on my stackexchange question as well. Another person answered with this design:
Im a bit confused about the placement of resistor between capacitor and relay? and whats the 2nd diode for?
BobTPH
Joined Jun 5, 2013
11,647
The resistor is there to limit the charging current of the capacitor. Without it, the relay would not energize right away as the capacitor was charging. It might or might not be a real problem.
ScottWang
Joined Aug 23, 2012
7,505
You didn't mention about the load, maybe you don't need to use the relay and can be use the NMosfet to save the energy from relay to load.
sghioto
Joined Dec 31, 2017
8,751
Would this design with R1 in-between Capacitor and relay, would that affect relay operation? What about wattage of R1, is 1/4W good enough?
What resistor value should I use for LED then?
It wont have any noticeable effect on the relay operation and I used a 1/2 watt 22 ohm resistor when testing.
As far as the LED resistor use a value that you think provides sufficient illumination.
Another solution is to use a mosfet to activate the relay coil with a much smaller size capacitor.
