Need to clarify this
bwd111
Joined Jul 24, 2013
117
In one of my post I was told that E stands for line voltage and E should be phase voltage in this equation if Im thinking this out correct in the calculation P=√3 x E X I
(√) I know this isn't the correct symbol and I don't know how to get the squared symbol to show
33,222
The use of E and V is not very standardized. Both generally mean electromotive force, which is measured in volts.
Similarly, what is meant by the term "line voltage"? Is it the voltage between one line and another? Or between one line and ground (or the neutral)? In most cases, it means line-to-line, but there, in practice if nothing else, there isn't universal agreement on what "line voltage" means and what "phase voltage" means. So best to be explicit in any situation in which it matters.
To get the "squared" symbol, use Alt-253 or just type ^2. So 3^2=3²=9.
If the square root symbol isn't the one you wanted and you wanted the squared symbol instead, then what equation were you trying to express? It sounds like it was completely different than the one you actually expressed, which begs the question of what purpose was served by posting an equation that you believe is incorrect?
33,222
Someone (Georacer?) has a blog or a sticky somewhere that lists many of the Alt-code characters. I used to use them alot (I didn't even know about the panel of characters that has many of them in the Go Advanced mode).
Unfortunately, most of my work is now done from a notebook without using an external keypad and I've never figured out how to input Alt-codes with it. So I've forgotten most of them. But you can quickly run through many of them by holding down alt, entering the code, and briefing releasing the alt key. The nice thing about entering the characters via alt-codes is that the cursor automatically advanced, unlike when you select them from the Go Advanced side panel.
bwd111
Joined Jul 24, 2013
117
So are you that E is line voltage or voltage to ground or voltage to netural in that calculation? and not phase voltage when its a calculation for three phase? If I learned anything from all my post it was that one simple calculation
33,222
Go back and look at where I have used that equation and you will see that I have explicitly stated what the necessary conditions were.
This is why it would be a good thing for you to work through the derivation of that equation yourself. So that you don't have to rely on memorizing what someone else somewhere on the internet has told you.
Just make a start at an attempt and I will help you work through it.
bwd111
Joined Jul 24, 2013
117
I know it is phase voltage and going on that
bwd111
Joined Jul 24, 2013
117
You do? You know this how? It came to you in a vision? A dream?
What do you mean by phase voltage? The voltage from one each phase to ground?
Missed the test question where the correct answer was line to ground
33,222
My version: You can lead a student to water, but it's still a felony to drown them.
33,222
All the more reason to walk through it yourself.
Why are you so adamant about not wanting to understand anything about the field you are studying? Do you want to be nothing more than an equation monkey that is a disaster waiting to happen?
