Need substitute for fsdmo465r
28,157
It is obvious that the original markings have deliberately been removed so that part number must be used. . Probably it is a commonly available component, most likely an amplifier. If we are given the application circuit probably a replacement type can be determined. It may be something like a TDA 2005, as an example.
28,157
The photo shows a 5-lead T0-220 PLASTIC PACKAGE with the original markings very deliberately removed. That part number is a manufacturers assigned number designed to hide the actual identity of the component.
IF we can get a description of the equipment that it was part of, and possibly a bit of the associated circuit, it will be possible to suggest an alternative.
Awsmps
Joined Jul 15, 2021
Used in a simple 48w power supply to run a motor
28,157
OK, it is used in a 48volt system to run a motor. Is there a way to show us any portion of the circuit, at least the power supply and motor connections to the IC? And any motor ratings, like voltage and current? That will be useful in determining what the device is.
Ian0
Joined Aug 7, 2020
13,252
