Hello all,
I have been working on a project controlling a coil to attract a metal bal at high speed.
I measure the speed of the ball in front of the coil and then decide how fast i want the ball to excelerate because the speed it need to have when it leaves the coil is about 10 m/s.
I found out i have about 9 miliseconds to use the coil. So what i was thinking is ill use a MOSFET and a pwm signal in this way i can change the dutycycle and then control the coil like in the drawing.
But i red on a site if i want this to work i need to switch high side and low side because else the coil still will be magnetic. now is my question: does somebody know what they mean and how does is work since i have not much experience with coils.
Specs:
PWM signal : 3.3v 10Khz
Coil: 51v 16A
Thank you in advance
Specs:
Coil: 51v 16A
