Need Some Assistance
KKH9
Joined Jan 11, 2018
I have a question as part of my assignment and need some guidance, any help would be appreciated
apporeciated
Part 1-
Derive and calculate the magnetic flux density in the core of a solenoid of length 30.48 cm that has n = 5000 turns of wire wrapped around a ferrite core, with a current of I = 500 mA passing through the coil. Assume the ferrite rod core has a radius of a = 10 mm and a relative permeability of μr = 6000
Part 2 - Calculate the self-inductance of this solenoid
Part 3 - Calculate the magnetic flux density at z = d/2 and z = 0 for the above solenoid if the length is reduced by a factor of 10.
WBahn
Joined Mar 31, 2012
33,109
In order to receive assistance, you need to show YOUR best attempt to work YOUR homework. That gives members something to work with to help identify what the point at which you are getting off track and to help get you past that point and moving forward.
