Hey,
I have 11 modules of Sharp NA-E120G5 and each produces 44.9vdc maximum
but 44.9vdc are insufficient for 2 pairs of 12vdc batteries connected in series i.e 48vdc.
what should i do to make them usable for my home use,please
also explain if can i use them with/without batteries and how?
1)Some one told me that i have to put a pcm6040(Taiwan) controller followed by the ups(with backup) with these solar modules to make 44.9vdc able to charge a 24vdc/48vdc system,then ups/inverter will supply 220VAC (required) for the house load.
Also he told me that this is the only way to make them usable for (1-phase 220vac) my house load.
2)If i make two groups of 10 modules that are connected in parallel fashion to each other while each group contains 5 modules connected in series making 44.9vdc X 5 =224.5vdc and 125w X 10 =1250w. Next are two options in my mind:
a) Make 224.5vdc to 220vac , to load(without batteries). (I don't know if it is possible or not and if possible please tell me detail.)
b) Make 224.5vdc to 12/24vdc ,then to batteries to inverter / UPS to load.do i need any controller for this?
Please tell me if some one has a better solution.
Thanks.
Thanks.
