Need sensors for weaving machines
Ani7428
Joined May 16, 2024
Can any one Suggest me a sensor for weaving industry
1-Humidity measuring sensor in thread
2-Thread breading sensor
if the red colored thread breaks . We need indication Automatic Start-mark Prevention.jpg
dovo
Joined Dec 12, 2019
72
What an interesting project.
Thread Breaking sensor
A piezoelectric sensor might be what is used. Each time the thread moves it outputs and signal and if the thread breaks and stops moving there is no more thread signal.
Eltex uses a piezoelectric sensor for their thread sensor. Eltex thread sensor https://eltex.se/products/eltex-thread-sensor/
Sparkfun has a piezoelectric sensor that might be useful. I don't find any documentation and am guessing the thread can be threaded through the brass hole?
https://www.sparkfun.com/products/9198
A similar part is stocked at Mouser, a TE Connectivity Measurement Specialties 1005940-1
https://www.digikey.com/en/products/detail/te-connectivity-measurement-specialties/1005940-1/726374
Datasheet https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1909/MiniSense_100.pdf
You can contact the company to discuss your sensor requirements.
Humidity Sensor
Is it air humidity you need to sense? TE Connectivity Measurement Specialties has these things.
SHT Temperature and Humidity Sensor
https://www.adafruit.com/product/50...zzFzJjaaL9_hRidjC6ELTkC3P2tHU2cUaAljVEALw_wcB
Digikey stocks many types of humidity sensors.
28,203
For the thread break detector you need to sense even one thread breaking. That is quite demanding because the threads are very thin and would not block much light. A high resolution optical line sensor will work, and not have any contact. It will require a computer to monitor the image and detect a missing thread.
28,203
To elaborate some more: The sensor could also be some version of camera, and the lighting be from the side so as to provide a maximum amount of contrast. Then the software will need to be able to monitor the image where each thread should be.
Read "Video Systems Design magazine on line to see adds from the folks who integrate those systems. That is not me.
