im putting push button start with remote start in my 2004 jetta gli. the door locks are negative trigger but the pbs requires a positive input. i have wired into the door lock wires but cant get the pbs to do anything when attached. another problem i have run into is if i wire them to relays the locks freak out as soon as i connect power or ground(dependant on how i wire up the relays). im trying to figure out a way to have them monitor the door lock wires but not have them activate the door locks.
