Need help with dark activated switch
35,073
Now expose the LDR to dim light, i.e. halfway between light and dark when you want the LED to switch on/off.
Then start with a very high value base resistor >1MΩ and gradually reduce the value until the LED just turns on.
Using a variable 1MΩ resistor is a convenient way of doing this.
The value resistor when this happens is the final value you need in your circuit.
sumit231996
Joined Oct 14, 2014
14
FD9QOPNGRYOQQEY.MEDIUM(1).jpg ohk will try it. Btw I found this one that I made for laser security alarm a year ago. It shares a common circuit (almost). Will this work if I replace buzzer and capacitor with LED's?
Alec_t
Joined Sep 17, 2013
15,152
The circuit in post #23 runs the risk of frying the transistor if the pot is inadvertently adjusted to its minimum resistance. Put a 1k resistor in series with the pot to avoid that.
You will probably need very bright light (or an LDR with a low dark-resistance) to get the transistor to switch off.
