Hi all, I am new to the forum, and from what I have read, new to wiring compared to most of you. My largest hobby is wrenching on cars, which has lead to my inquiry.
Goal: I want to wire accessory interior lights into one of my cars to be controlled by the existing light/dimmer combination switch.
Problem: I understand the on-off function of the switch. I plan to use the outgoing signal from the switch to activate the relays which will be controlling each individual accessory. What I do not understand, is how to use the dimming function to also dim each individual accessory.
It is my understanding that relays are always either on or off. I am not knowledgeable of what type of Hardware I will need to interpret the outgoing signal from the dimmer switch and feed it to each accessory I am adding.
Essentially I want the existing light switch to be used solely as a signal and not a source of power. I will be using fuse blocks and relays as mentioned to power the accessories.
I like to disturb the OEM engineering as little as possible. And I hate splicing wires! I always de-pin and re-crimp connections when possible.
Thanks in advance for any help, if you could point me in the direction of the hardware I need, or take me to school if I'm way off, I would really appreciate it.
