As far as charging your batteries;
Modern electronically controlled chargers use several different phases:
1) Bulk charge - This is when the battery is heavily discharged. High constant-current charging occurs until the battery is approximately 80% charged.
2) Absorption charge - The battery is charged at a constant voltage (roughly 14.4v, but varies by the battery internal temperature) until about 98% charged.
3) Float charge - The battery is charged at a lower voltage than phase 2), actual voltage is determined by internal battery temperature and battery construction.
Occasionally, standard "wet-cell" lead-acid batteries must be given a maintenance "leveling" overcharge to stir the electrolyte.
