Need help with a rotary switch..
brontozaur1
Joined Apr 12, 2018
12
Hi all,
So I am repairing an active speaker and there is this rotary on/off switch that I want to test/replace if necessary.
I suspect that it's faulty.
http://www.alpha-product.net/en/product/Rotary Switch/RS17 Serials/907/
I just can't understand that data diagram. Which pins does it short when turned on?
It has 10 legs, 4 of them are connected to tracks on the PCB (two on each side).
I suspect that it's faulty and I want to replace with a simple toggle on/off.
What does 'stopper' (envelope sign, or 'C') mean?
Any help would be appreciated..
ericgibbs
Joined Jan 29, 2010
21,548
hi,
If you look at the switch from the shaft end [ knob fitting view] the switch rotation is defined.
The 'C' means the Common or switch wiper.
E
ericgibbs
Joined Jan 29, 2010
21,548
hi,
The way I read the switch diagram is:
Pins 1 and 10 are the wipers, so in position #1, pin2 is connected to C.
Look at this marked up diagram, there appears to be only two switch positions used.
E
brontozaur1
Joined Apr 12, 2018
12
hi,
E
Many thanks, will try to wire it like this and see if it works. I was wondering what is the function of these two capacitors?
If I connect it accordingly, it seems they are of no use, or am I wrong?
