Hi everybody, i'm new on this forum; i'm in need of help using an INA 52063. I use it as a 2nd stadium after a transimpedance amplifier and the problem is that when i turn on the DC generator the amplifier heats up and breaks .
The layout used is the same shown in the application notes of the datasheet, and the supply is +5V. I've also added a 50 ohm parallel resistor at the output for impedance matching.
Thanks for the help^^
