Need Help with 54V dc rectifier and regulator design.
mastero1976
Joined Sep 10, 2022
Hello Friends,
Since this is my first post would like to introduce myself ...
I am from India and run a automobile workshop designing PCB and electronics is an hobby. Have completed numerous projects with Microcontroller .
I am here for some help and advice.
As you can see in the enclosed design Single Phase full wave shunt rectifier and regulator. It is designed for 15vdc scooter charging circuit.
I was thinking of modifying the stator and producing 100v @ 5k RPM which can be fed to MB254 and give me unregulated dc volts.
what mods do i have to do to make the regulation part work at 55Vdc.
a) 12vZener needs changing
b) 22uf/25v caps needs changing
anything else ??
Thanx for your help and advice
cheers
mastero
LowQCab
Joined Nov 6, 2012
5,101
Do You realize that You will not get any more "Power" ?
in other words, when You increase the Voltage by ~4.5X,
the maximum Current available will be reduced by ~4.5X.
How much Current do You need at ~55-Volts ?
What type of device do You want to provide Power to ?
mastero1976
Joined Sep 10, 2022
Hello LowQcab,
Thanx for the reply.
I know higher voltage will reduce the amps.
I just want 54vdc @10amps, to charge a Lithium battery pack. 48V/36ah
any suggestion / advice ?
cheers
mastero
LowQCab
Joined Nov 6, 2012
5,101
That's ~540-Watts.
"" I was thinking of modifying the stator .......... ""
Are You talking about modifying the Stator on a Scooter-Engine ?,
You will never get ~500-Watts from a Scooter-Engine.
If You are really good at designing a completely new Alternator-Coil and Magnet-System,
You "might" get ~50-Watts ........... maybe ........... if you're lucky.
50-Watts would equal around ~55-Volts at less than 1-Amp.
