hello sir and thank you for reply . i want to creat a baord with an atmega1280 chip and a k thermoucoples and ihave to amplifie the signal from the k thermou so it can be read by the atmegaThis is a useless Schematic.
It will continuously oscillate, and not provide any useful function.
( Unless it's supposed to provide some sort of special PWM-Output )
Why don't You simply state what You are trying to achieve, ( in detail ) ?
If you want to do this easily and quickly use a MAX31855 IC connected to the ATmega1280 via I2C 2-wire interface . Don't waste your time, money and sanity messing around with discrete op-amp & ADC solutions, you'll be in a world of non-linearity and drift and the chances of getting a useful reading are minimal... been there, done it.;..hello sir and thank you for reply . i want to creat a baord with an atmega1280 chip and a k thermoucoples and ihave to amplifie the signal from the k thermou so it can be read by the atmega
why?This is a useless Schematic. It will continuously oscillate...
No.am i missing something?
by Aaron Carman
by Jake Hertz
by Lisa Boneta.
by Jake Hertz
