Need help understand compressor wiring
fouad belkhadem
Joined Jun 28, 2018
26
Dears,
Please need some help with dammaged screw compressor mahle msk-g controller.
The connector illustration is in german and could not understand most of them (attached picture).
Planing replace the dammaged with arduino board.
yellowfish
Joined Feb 9, 2009
44
Ok here it goes. I translate only the items not in English language:
#6 = pressure
#8 = rotation direction
#9 = external fault
#10 = ext. power on
#11 = ext. load
#12 = PTC overload protection
#13-20 are just indicators.
This seems to be a motor variable frequency drive VFD. Go to automationdirect and buy an off-shelf unit, rated for the motor HP and voltage.
Arduino won't do it, perhaps three of them.
fouad belkhadem
Joined Jun 28, 2018
26
Thanks a lot for your support,the motor is 3 phase induction motor,only one direction with star delta start.
So 6 is for 420ma pressure sensor.
8 perhaps to detect if the notor rotate on wrong direction if one phase is absent.
12 i thing go to the switch on termal protection.
I wondering where goes ,tublure temp sensor,snd motor temp sensor,and inlet electrovalve,also there is oil radiator that should be cooled co fan.
