Need help selecting IR Sensor
dell101
Joined Jan 21, 2017
12
Hi All,
I am trying to build a IR Repeater circuit. I have seen products which do the same.
The issue that I face is that these products claim to support frequencies between 38-56kHz. When i look for using a TSOP i find that it always comes with a fixed frequency. For Example the Vishay TSOP1138 supports only 38 kHz. There are TSOPs supporting different frequencies but there is none that supports a frequency band.
I also dismantled one of the product to get the model number but it just says CHH 11388 (I think)
Products:
https://www.amazon.com/External-38-56kHz-Receiver-Extender-EXPLORER/dp/B0107LT77S
https://www.amazon.com/dp/B01KTFT39E?psc=1
Could someone please help?
Many Thanks.
S
wayneh
Joined Sep 9, 2010
18,175
Do you know what frequency you are trying to match, and do you know that you need a range?
If you look at the data sheet for the TSOP1138, you'll see that the response is centered at 38kHz but will maintain about half the responsivity over the range of 38±10% = 34 - 42kHz. Maybe that's good enough?
dell101
Joined Jan 21, 2017
12
Thanks Wayne. I want an IR receiver to support freq. range 38 - 56 kHz frequency band. Because the IR Repeater should be able to work with any AV equipment. The AV equipment remotes can work in any range between 38 to 56 kHz.
ian field
Joined Oct 27, 2012
6,536
Hi All,
When I built a remote handset tester, the IR sensor was liberated from a scrap VCR - I haven't the faintest idea what frequency band it was made for. From the shopping bag of remotes, only a few failed to trigger the tester - some of those were identified as faulty and did so after repair.
There's various schematics archives for TVs from the era when the IR unit was a tiny PCB with a basic IR PD and a few discretes or a chip, they're a valuable resource of what the circuitry looked like - but a few manufacturers didn't bother including this info on the schematic.
Products:
Many Thanks.
S
Sensacell
Joined Jun 19, 2012
3,789
If you are trying to build a "repeater" using a integrated receiver module, you will need to replicate the carrier (30-50 khz) to the LED.
The receiver modules will give you the pulses, but strip out the carrier waveform.
You will not find an RX module that supports a wide range of carrier frequencies, it's an oxymoron.
EM Fields
Joined Jun 8, 2016
578
Hi All,
Products:
Many Thanks.
S
All a repeater does is receive the modulated infrared signal, amplify it, and send it on its way without regard to the information it carries.
ian field
Joined Oct 27, 2012
6,536
There have been repeater projects published that were based on the 555 - can't remember which magazines, but there aren't many to search through now.
