Need Help! Remote Controlled Switch
kayjabbar
Joined Sep 8, 2016
50
hi,
This is what I see from the Images you have posted, You have the PCB in front of you.!
If you can clearly see the resistors and LED connected in the way you state, then do it that way.!
E
I don't have PCB in front of me but the part you are labelling as the LED is the Resistor and the horizontal resistor you labelled just below FC pad is the LED, am I right?
ericgibbs
Joined Jan 29, 2010
21,573
hi,
As I said I only have that poor first image you posted as a guide.
If you are sure that the LED is connected to the FC pin, then the circuit could be like this image.
When you get the PCB in front of you , take and post a clear image.
Did you understand my post about the Heating query you had.?
E
kayjabbar
Joined Sep 8, 2016
50
No I did not found where you replied to that heating query, is it represented by the graph in third last post of yours?
Can you elaborate along with the graphical representation?
Thanks in advance!
kayjabbar
Joined Sep 8, 2016
50
Because it would be hard to find same part numbers and i have some p channel mosfet and pnp transistors on a donor board nearly same specs
