VBATT SENSE and PP BATT VCC are "signals." They may be I/O, sensors, even power from what you have shown. They go to something on the rest of the schematic. What is it that you do not understand?
The circled numbers may be anything. In context, they may be pin numbers on connectors.
Thanks for your response,
That's right they go somewhere in schematic, I did followed and it goes to two IC,
non of them have this pins on them,
so what do they stand for?
How can they "go to" an IC if the IC has no pins? Please express your question in a more clear manner.That's right they go somewhere in schematic, I did followed and it goes to two IC,
POST THAT PART OF THE SCHEMATIC!They go to an IC!
The IC doesn't have any pins numbered 23 or 50.
Any idea?
Here is the rest of schematic hope this can help.Without seeing the rest of the schematic, that is impossible to determine.
I can't the whole thing in here, but that's where it only goes.That png file shows only a part of the schematic.
I checked it's not about the page.I bet there is the same signal shown on pages 23 and 50 of that schematic. That´s where it goes and what it means.
This:
is the one end of a bus (notice the darker line) that has signals BATT U3 300-A1 ...BATT U3 300-E1. The schematic happens to show and label each pin. The C1 signal goes here:
Note that C1 goes to multiple pins that are individually numbered C1...C3.
Those small numbers on the bus or signal lines that exit the page are probably page numbers. Except for the multiple pages, there is noting there that isn't in the free version of EAGLE. One may simple decide not to show that information.
I don't think so. Probably just multiple inputs to the IC to enable higher input/output currents.This is the one end of a bus ...
