Need help in Aptitude Question
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Two cars are traveling at 60 mph and 45 mph respectively. If the faster car travels two hours longer and twice as far, then:
What are the distances traveled by each car?
What are the operation times of each car?
Ta+2 hours
Da+2
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Ta+2 hours
Da+2
@RRITESH KAKKAR
Time for me to sign off for the nonce (Zzzzzzz)--- Please ask @WBahn how he wishes you to approach the problem -- Not being 'raised' on the 'unit tracking' technique myself - I am not an ideal teacher of said practice:oops: (Please note that @WBahn is a Bona Fide instructor!:) -- Hence, if he advises that tracking units is good practice - you can bet on it!:cool::cool::cool:) --- So please work on it -- I'll look in tomorrow at the same time:)
If you're experiencing difficulty or if @WBahn was unavailable I'll assist you with the exercise --- FWIW My purpose in posting that particular exercise was/is to encourage your adoption of the 'simultaneous solution' approach -- so please 'tend to that' as well!;):)
Chat with you tomorrow...
Very best regards
HP:)
WBahn
Joined Mar 31, 2012
33,348
Ta+2 hours
Da+2
"Ta + 2 hours" is just an expression and, by itself, doesn't convey any information. You need to establish relationships between the various variables using equations, not expressions.
Since you are somewhat on the right track, I will give you the first one:
"Car A travels two hours longer than Car B" translates to "Ta = Tb + 2 hours". Since I said that I didn't want you using numerical quantities until the end, we use Td for the amount of time by which Car A travels in excess of the time traveled by Car B. So "Ta = Tb + Td".
Now you translate "Car A travels twice as far as Car B" to get an equation involving Da and Db.
WBahn
Joined Mar 31, 2012
33,348
Ta = Tb + 2
Ta = Tb + Td
Tb + 2=Tb + Td
D=S*T
Da=Sa*Ta
Da=60*Tb + 2
Db=Sb*Tb
Db=45*Tb
UNITS !!!!!!!
ORDER OF OPERATIONS !!!!!!!!
SYMBOLIC ONLY !!!!!!!!
If you have
Da = 60*Tb + 2
what you really have, because of order of operations, is
Da = (60*Tb) + 2
and you will end up with the wrong answer and be scratching your head wondering where things went wrong. As you work more complex problems you simply can't rely on "knowing what I meant" to avoid the consequences of sloppy math.
If you track your units, you would see, at some point, that
Da = (60 mph * Tb) + 2 hours
results in 'distance' + 'time', which makes no sense. And this nonsense would propagate itself through your work until it slapped you upside the head and forced to realize that you had made a mistake and it would then provide a roadmap right back to where the mistake was made, allowing you to correct this to
Da = 60 mph * (Tb + 2 hours)
and then work forward from there instead of having to start over from scratch.
But, having pointed all of that out, I told you that I don't want to see any numbers until you are ready to get the final answers. So at this point you should have:
Ta = Tb + Td
Da = Sa*Ta = Sa*(Tb + Td)
You have four unknowns, Ta, Tb, Da, Db, so you need four (independent) equations. You have two. The first is from the constraints given in the problem involving the times and the second is from D=S*T for Car A. So get a third from the constraints given in the problem involving the distances and a fourth from D=ST for Car B.
WBahn
Joined Mar 31, 2012
33,348
My beatification as I live and breathe -- Golly, Golly!!!:D:D:D
Is it just me, or does it seem strange that the root of beatification is "beat"? :D:D:D
(and, yes, I know that it is really Latin "beatus" -- but that begs a similar question of whether "beating someone" means you are blessing them. :D)
I think I will tell my daughter next time she gets in trouble that she is headed for a "blessed beating"!
@RRITESH KAKKAR
As an aside -- Once having properly stated the equations in the unknowns - please recall that simultaneous solution requires inclusion of all said expressions! --- Hence, if you will be solving via substitution, you must select one unknown then 'combine' all equations 'in terms' of same --- Alternately, you may solve (simultaneously) via 'cancellation' (the preferred method, IMO).
One caveat: While said approaches are readily applicable to 1'st degree equations - care must be exercised with non-linear expressions - lest complication owed to extraneous and/or 'lost' solutions become manifest!:eek::eek::mad:
Hint: As regards the current exercise - simultaneous solution will be straightforward! :):):)
Best regards
HP:)
