Need help in Aptitude Question
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
If 6 men and 8 boys can do a piece of work in 10 days while 26 men and 48 boys can do the same in 2 days, the time taken by 15 men and 20 boys in doing the same type of work will be:
Yes.
M=1/100 or 100days
M=1/200 or 200days
M*15=15/100
B*20=20/200*20
15/100+20/200=4days
In my opinion
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
A can do a piece of work in 4 hours; B and C together can do it in 3 hours, while A and C together can do it in 2 hours. How long will B alone take to do it?
A=1/4 in work done in 1 hr
B+C=3 hrs
1/B+1/C=1/3 in work done in 1 hr
A+C=2
1/A+1/C=1/2 in work done in 1 hr
b=?
is this right?
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
B+C=3 hrs
A+C=2
b=?
Inasmuch as you seem to have retired for the nonce -- I'll leave you with this:
Ordinarily I'd advise writing three equations (i.e. solutions of each variable in terms of the other two) for simultaneous solution...
Once again, however, it seems we've been offered a 'trick question' and, hence, a 'short cut'...
Given that A, B, C represent the task completion times required by the respective workers:
Note that the above quoted stipulations tell us that A=C
Hence, via:
1/(1/4+1/B)=3 --- Solve for B
@RRITESH KAKKAR
While I'm not in the habit of conducting 'walkthroughs' -- I felt it appropriate to assist you in 'spotting' trick questions and otherwise making labor-saving observations...
Best regards
HP:)
WBahn
Joined Mar 31, 2012
33,348
Yes.
M=1/100 or 100days
M=1/200 or 200days
M*15=15/100
B*20=20/200*20
15/100+20/200=4days
In my opinion
So if someone asked you what was
15/100 + 20/200
you would say that it is 4?
Your sloppiness with units is going to keep getting you into trouble.
\( 15 men \) \(\frac{1}{100} \frac{\(\frac{job}{day}\)}{man} \) \; + \; \( 20 boys \) \(\frac{1}{200} \frac{\(\frac{job}{day}\)}{boy} \) \; = \; \frac{15}{100} \frac{job}{day} \; + \; \frac{20}{200} \frac{job}{day} \; = \; \frac{1}{4} \frac{job}{day}
or 1 job per 4 days.
15/100 + 20/200
That's my fault, @WBahn -- I've been too lenient as regardes skipped steps, etc... (Case in point: reciprocation) :oops::oops::oops:
@RRITESH KAKKAR
Please examine post #937 closely! -- Notice that @WBahn 's approach of tracking/annotating units/entities results in self-documenting work -- thus 'bonding' the 'abstract' to the 'concrete' and, thereby, rendering most common errors obvious! - You will find said practice/habit of significant and increasing value as the complexity of the problems increases:):):)
Best regards
HP:)
WBahn
Joined Mar 31, 2012
33,348
@RRITESH KAKKAR
Best regards
HP:)
Oh, not to worry.
I consider three different categories of errors at play -- each deserving a different kind of response.
Units -- For ME this is a cardinal sin, but I realize that most people don't agree. So while I will harp about it as much as I can -- particularly when not tracking them results in mistakes not getting caught -- I generally don't jump and shout when others ignore them.
Missing steps -- This is definitely in the eye of the beholder and is also very context sensitive. If someone gives the general impression that they are mathematically competent and if their work is otherwise correct, I seldom say anything. But if the result isn't correct and there's not enough work shown to begin to spot where the error is, then it quickly becomes an issue, particularly if the person continues to not show their work despite continuing to make mistakes.
Sloppy math -- This I harp on whenever I see it (and, a few times, I've harped on it about a post that I made where I got sloppy -- I generally leave the error in place but add an edit note indicating that is it wrong and which post to look at for the correction). There are lots of common places where people get sloppy and reciprocation is certainly one of them. Another is writing expressions that violate order of operations, such as saying 15/3+2 = 3, and expecting everyone to just "know what I mean". This is the kind of sloppiness that really gets people into trouble -- and it's a kind of sloppiness that tracking units will almost always catch.
JohnInTX
Joined Jun 26, 2012
4,787
@WBahn Keep harping!
I used to harp at my kids the same way when helping with their math homework. Units ("Do them!"), Missing Steps ("Paper is cheap, show your work!"), Sloppy Math ("Recheck your answers - its easy if you pay attention to the first two rules").
It worked. My daughter's math-fu got her several research fellowships on her way to an MD. My son graduated USNA in economics of all things and wound up in Nuclear Power School for subs. He made it through when about 20 classmates washed out -many of those graduated in engineering. When I asked him how he managed to do it he said "Math, dad. I'm better at math then they were. You taught me how." I didn't teach him any of that but he did remember my harping on how to approach math and the insistence on actually getting to the correct answer, no partial credit for DadMath. It turns out there is no partial credit for nuclear reactor math either.
Harp on, friend! Someone will get it.
