Ok, so this schematic is most likely the correct one then? I understand the difference in the start up resistors and how they modified it. But what about the different readings and values present on the previous resistors I was testing?
Or do you think the problem is elsewhere like at the transformer to UC2804 circuit? I am just wondering what I am looking for when I find the circuit you mentioned.
Ya I was amazed at the resolution it had. I read somewhere to use a scanner bead and cover it with something black to keep out ambient light out. So I scammed it I'm at the highest setting it would go and it was clearer then using a magnifine glass. So did you come to the same conclusion that resistor in question had "100" printed on it?
