The phone is only use for announcement I will remove the speaker connect amplifier and siren connect to amplifier outputs. But i am afraid that the phone speaker to amplifier may not work because that is speaker signals not line signal for amplifier input. I’m worry that it damage the amplifier I need some guidance on how to about hook it upIt looks lIke the telephone speaker is in a telephone handset so it will have a signal level low enough to connect directly to both inputs of the stereo amplifier.
But where will you connect the siren? With a switch to select siren or telephone?
Does the siren have a line -level output?
You think Is ok to connect amplifier input directly to phone speaker wire?The phone is only use for announcement I will remove the speaker connect amplifier and siren connect to amplifier outputs. But i am afraid that the phone speaker to amplifier may not work because that is speaker signals not line signal for amplifier input. I’m worry that it damage the amplifier I need some guidance on how to about hook it up
If you think is ok. Then I will try and see if it works. Thank youYou think Is ok to connect amplifier input directly to phone speaker wire?
The phone got only one speaker. Do I split the wires and connect directly to left and right input chanel of amplifier?If you think is ok. Then I will try and see if it works. Thank you
I thought this siren is a pa speaker siren so it works like a speaker for voice so I connect in place of a the speaker. The way it work is that i can call the phone from anywhere the phone pick up that when i make the announcement through that phone. So no switch needed. I have test with connect from phone to line level converter then connect to 1 channel of 10w amplifier then to a computer speaker. It works, but It just loud enough to wake wife from sleeping to do cooking before you come home. For a commercial building I need it louder. I not sure of I plan to use siren and more power amp. I not familiar how siren work also I would like it as loud as i can get. What you think?Is the speaker in the telephone actually the earphone in the handset? If it is then its level is almost line level and will not cause damage.
"I will remove the speaker connect amplifier and siren connect to amplifier outputs." This makes no sense.
You do not connect a siren to the amplifier outputs. Instead the siren connects to the amplifier inputs. But you need to switch between the siren and the phone announcement.
I thought this siren is a pa speaker siren so it works like a speaker for voice so I connect in place of a the speaker. The way it work is that i can call the phone from anywhere the phone pick up that when i make the announcement through that phone. So no switch needed. I have test with connect from phone to line level converter then connect to 1 channel of 10w amplifier then to a computer speaker. It works, but It just loud enough to wake wife from sleeping to do cooking before you come home. For a commercial building I need it louder. I not sure of I plan to use siren and more power amp. I not familiar how siren work also I would like it as loud as i can get. What you thinkIs the speaker in the telephone actually the earphone in the handset? If it is then its level is almost line level and will not cause damage.
You did not post links to details for the siren and for the amplifier. Please post them.
You showed a photo of PA speakers that are MUCH louder than an ordinary speaker, please post a link
https://www.pyleaudio.com/sku/PHSP4
Is for the siren.
https://www.ezvapore.com/index.php?main_page=product_info&products_id=349448
Is the amplifier
The phone only got wire for one speaker. Do I connect both line input channels amplifier to that one speaker wire on the phone or do I need any adapter to connectThe PA speaker produces 100dB with an input of 1W. An ordinary speaker produces about 87dB with an input of 1W so the PA speaker is MUCH louder. It will be 110dB with 10W and will be 117dB with 50W at a distance of 1 meter. The dB loudness drops -6dB for each doubling of distance.
You did not post links to the siren and amplifier so I know nothing about them.
Maybe the amplifier is stereo with two channels then one channel can feed one PA speaker for the siren and the second channel can feed the second PA speaker for the announcement.
My mistake. It is a horn speaker actually that just looks like a siren. Not a siren. It is a speakerUNless a siren function is required there is no reason in the world to consider using a siren speaker for a PA system. For PA use where speech must be understood us a PA horn speaker. It is not likely that the TS will be able to access the speaker connections in a siren speaker assembly, and of course that MUST happen to connect to the speaker for PA voice use.
Do you have a link to that module?I think the telephone earphone (he calls it a speaker) feeds both stereo amplifier inputs and is used for making the announcement.
Maybe he planned to replace the stereo amplifier he showed with an expensive siren with horn speaker and 2 channels amplifier.
Here is a cheap little siren module sold on all Chinese online sites. Another circuit must be designed to activate the siren for a couple of seconds when the phone rings. Then the phone calls about Duct Cleaning and Windows And Doors can wake his wife and his entire neighbourhood.
Will his wife hang up the phone?
See the response in post #15. It is actually a horn speaker, not a siren device. The big problem with siren speakers is that the actual impedance is unknown, and the distortion may be very high.I think the telephone earphone (he calls it a speaker) feeds both stereo amplifier inputs and is used for making the announcement.
