Can anyone help me solving this circuit? I need it as soon as posible, since the exam is in about two days. Thanks
Nothing... I just don't have Idea how to start solving this out..So what have you done so far to solve the problem besides ask us?
I can't even imagine what u try to tell me... can u please send me a picture of transformation?Could you solve the problem if there were no R2 and the transistor was simply a diode in series with R3?
Thanks! This helps a lot.If you don't have any idea how to solve a problem, it often helps to write down what you know about the various parts of the circuit.
Of course it does. He basically did what he shouldn't do. Gave you the complete solution.Thanks! This helps a lot.
You mean that just making a few simple observations about the circuit, you get the complete solution? Who would have thought that?Gave you the complete solution.
I think those few simple observations should be made by him. Those observations are all he needs to solve the problem. Now, the only thing he needs is to plug in values and get the results. That way is easy and probably he won't be able to solve a new problem even with the same level of difficulty... Anyway, I'm no one to say anything because I'm also a complete rookie. I just learn from the examples I've seen in the forum where no one should solve the other's problem but help to spot errors or help leading in the correct direction to solve a problem...You mean that just making a few simple observations about the circuit, you get the complete solution? Who would have thought that?
