Hi, noob here. I've got some 3-5vdc delay timer modules that require a short falling trigger pulse to activate the delay. If it is possible I'd like to use an LDR to trigger this pulse so it will only trigger when it is dark outside. The module will be li-ion powered and will be used for some 3v leds. Hopefully someone will be able to help me figure this out. Thanks in advance for any advice you can provide. John
