I have a interesting problem with the electrical supply that runs in to my mobile home I found that one leg is almost missing it only measures 23v on my meter while the other leg is fine measuring 120v like it should the way that I started to investigate this was all the circuits for the kithen were not functioning I opend the panel inside the house (I guess you can also call it a sub panel sinse there two breakers located outside right under the edison meter) and found that one side of the buss bar was dead I tried to reset the breakers out side but still one leg was not supplying what it should I called the park manager he told me that the wrong breaker was installed I not sure but i dont think that has much to do with it the only thing i can think of is that maybee the sub feed is damaged somewhere and this is causing my problem. any ideas ,comments sugg,or advice would be greatly appreciated
