I have nothing to show youShow us what you did so far.
Actually I am newly student of computer science and with study I am doing job.That's exactly I am unable to solve this Task.Still you don't want to believe me, then I say your wise.So...what are you studying ?
Give you a lead.Suppose a university’s research committee comprises of five members e.g. A, B, C, D, and E. When a research proposal is received by the committee, then it is reviewed by all the members for approval. Each member gives his consent regardless of the other to approve or disapprove a proposal. If three or more than three members give their consent in favor of that proposal, then that proposal will be approved otherwise it will be rejected.
As an engineer, you are asked to analyze the situation and draw logic circuit diagram to show whether a specific proposal will be approved or not.
Tasks:
i. You will first use truth table for your inputs and outputs (A binary 1 represents approval and binary 0 represents disapproval).
ii. Simplify your expression obtained from truth table by using any expression simplification technique studied so far.
iii. Draw logical circuit diagram for that simplified expression.
If you don't know enough to get started, you need to meet with your instructor and get remedial instruction.I have nothing to show you
analyzing some situation to simplify its logic by any Logic Simplification Technique and drawing Circuit Diagram out of it.Give you a lead.
Under which logical conditions will an approval be given?
Here is a repeat of your problem. Can you summarize it in your own words? Being a computer person, maybe you can flowchart the process described?Suppose a university’s research committee comprises of five members e.g. A, B, C, D, and E. When a research proposal is received by the committee, then it is reviewed by all the members for approval. Each member gives his consent regardless of the other to approve or disapprove a proposal. If three or more than three members give their consent in favor of that proposal, then that proposal will be approved otherwise it will be rejected.
And that's the amount of credit you deserve.I have nothing to show you
Utter babble. Consider transferring to a management training program in the hospitality industry.analyzing some situation to simplify its logic by any Logic Simplification Technique and drawing Circuit Diagram out of it.
What is that some situation that means an Approval is given?analyzing some situation to simplify its logic by any Logic Simplification Technique and drawing Circuit Diagram out of it.
