Need an old paper by R D Middlebrooke
Dibyaranjan Senapati
Joined Jun 11, 2016
hello guys. if anyone is having any knowledge where I can find the below mention paper please let me know.
  1. Design techniques for preventing input-filter oscillations in switched-mode regulators, by R D Middlebrooke
bertus
Joined Apr 5, 2008
23,006
Do you mean this?
https://web.archive.org/web/20170623224736/http://www.smpstech.com/filter00.htm
Middlebrook, R. D., and Slobodan Cuk, Advances in Switched-Mode Power Conversion, Volumes I and II, 2nd Edition, TESLAco, 1983. 533 p. Available from TESLAco, #10 Mauchly, Irvine, CA 92718, Phone (714) 727-1960. (First edition c 1981.)
The first two volumes in the collected papers of the Power Electronics Group of the California Institute of Technology. See Cuk for the third volume.
Volume I (Modeling, Analysis, and Measurement) paper titles are:
  • Power Electronics: An Emerging Discipline;
  • Power Electronics: Topologies, Modeling, and Measurement;
  • Low-Frequency Characterization of Switched Dc-to-Dc Converters;
  • Describing Function Properties of a Magnetic Pulse-Width Modulator;
  • A Continuous Model for the Tapped-Inductor Boost Converter;
  • A General Unified Approach to Modeling Switching-Converter Power Stages;
  • Input Filter Considerations in Design and Application of Switching Regulators;
  • A General Unified Approach to Modeling Switching Dc-to-Dc Converters in Discontinuous Conduction Mode;
  • Modeling and Analysis Methods for Dc-to-Dc Switching Converters;
  • Design Techniques for Preventing Input-Filter Oscillations in Switched-Mode Regulators;
  • Modeling and Analysis of Switching Dc-to-Dc Converters in Constant-Frequency Current-Programmed Mode;
  • Characterization and Implementation of Power MOSFETs in Switching Converters;
  • Transformer Modeling and Design for Leakage Control;
  • State-Space Average Modeling of Converters with Parasitics and Storage-Time Modulation;
  • Predicting Modulator Phase Lag in PWM Converter Feedback Loops;
  • Using Small Computers to Model and Measure Magnitude and Phase of Regulator Transfer Functions and Loop Gain;
Volume II (Switched-Mode Topologies) paper titles are:
  • Basics of Switched-Mode Power Conversion: Topologies, Magnetics, and Control;
  • A New Optimum Topology Switching Dc-to-Dc Converter;
  • Coupled-Inductor and Other Extensions of a New Optimum Topology Switching Dc-to-Dc Converter;
  • Switching Dc-to-Dc Converter with Zero Input or Output Current Ripple;
  • Discontinuous Inductor Current Mode in the Optimum Topology Switching Converter;
  • Isolation and Multiple Output Extensions of a New Optimum Topology Switching Dc-to-Dc Converter;
  • A New Battery Charger/Discharger Converter;
  • A Conceptually New High-Frequency Switched-Mode Amplifier Technique Eliminates Current Ripple;
  • Modeling and Design of the Cuk Converter;
  • Design of a Kilowatt Off-Line Switcher Using a Cuk Converter;
  • General Topological Properties of Switching Structures;
  • A New Zero-Ripple Switching Dc-to-Dc Converter and Integrated Magnetics;
  • Advances in Switched-Mode Power Conversion, Part 1;
  • Advances in Switched-Mode Power Conversion, Part 2.
Bertus
SamR
Joined Mar 19, 2019
5,535
@bertus gave you the link to it...
Do you mean this?
Looking in and following that link is...
The paper is in Volume One of the series. Searching various online PDF repositories yielded no results as well as using BookFinder.com: Search Results (Matching Titles) to find library or used books resulted in no hits. Sorry and good luck.
