Need an idea for reading NFC micro-chips from 10cm
Kanc1erz
Joined Nov 30, 2023
there are some NFC micro-chips, 2mm x 2mm or 3mm x 3mm and I seek for a solution that would enable me to read those chips from a distance of approx. 10cm or at least 7cm.
I bought two ST's eval boards - ST25R3911B and NFC03A1 (1.4W and 250mW) and I wasn't even able to read the smaller chip, and the bigger one - I need to put it directly on the PCB antenna to get a proper readout.
I tried different antennas and also to tune slightly them on the ST25R3911B, but without success.
Is there a possibility to meet my expectations?
28,395
My first suggestion is to read the manufacturer's data sheets regarding the devices. The reality may not coincide with your expectations. And if you purchased them from amazon, the description may not have been correct, nor even slightly similar to the truth.
Kanc1erz
Joined Nov 30, 2023
I know the limitations of the chips - up to 20mm, but I think that this is the matter of the powerful enough transmitter and enough sensitive receiver to be able to read from a longer distance. Or at least I think so.
Alec_t
Joined Sep 17, 2013
15,157
You want 10cm. If signal strength reduces with the square of the distance (I don't know if it does for those devices), then you might need a transmitter/receiver with 25 times the normal power/sensitivity.
