Need a simple XOR for Car turn signal
35,170
I know this is an old tread, but the question is timeless, so I'm replying for the benefit of future readers.
I've always solved these things using SPDT (Single Pole Double Throw) relays in the past, but because non-American cars tend to disconnect a wire when off instead of connecting it to ground (so you get either 12V or floating, while you need 12V or ground), you end up with quite a few relays.
You do this by connecting the coil of the relays to ground and the other side to each of the signals (right turn signal, left turn signal and parking light), the Normally Closed pin to ground and the Normally Open pin to 12V. The common pin if the new output.
You can now connect the new output from one of the turn signal relays to one side of the coil of a relay and the new parking light output to the other side. The relay will then switch on if either parking light or turn signal is on, but off if none or both are on.
Hence, in this case you end up with 5 relays (7 if you also want to combine brake light and rear turn signals in one bulb as well).
I recently learned another trick. If you first use 3 SPDT relays to convert the floating/12V signal to ground/12V, you can use a simple rectifier or diode bridge in place or a relay or an XOR gate to produce the wanted effect with the marker lights.
Connect the (ground/12V) parking light wire to one of the AC inputs of the rectifier and the (ground/12V) turn signal wire to the other, then connect the plus and minus output from the rectifier to the marker light. This will work both with LED lights and normal bulbs (provided you use a strong enough rectifier).
A picture is worth a thousand words. Draw a schematic.
