Need a rotary pot with momentary(spring loaded) push/pull action
nadimaj
Joined May 28, 2013
8
I'm looking for a rotary switch/potentiometer that has a built in momentary (spring loaded) push/pull action. The standard Bourns B10K pots are almost perfect but they have just a push function. I need those, with an equally spring loaded pull function.
Bourns does do rotary pots which describe themselves as push/pull but I have a feeling they are not spring loaded/momentary. I'm looking at the Bourns PDB183, but as usual the datasheets give no indication of physical operation. Videos I've seen of other Bourns pots are for guitar applications where the switch is either in or out. I.e. not spring loaded to return to the normal position. Anyone have a suggestion?
Thanks
nadimaj
Joined May 28, 2013
8
Thanks but not what I'm looking for. Need more of a volume dial type rotary switch that you can push in and pull out.
Edit to original post: The standard Bourns B10K do not have push. That is something else
