Need a 220v converter for my new VFD - How many watts?
tcmtech
Joined Nov 4, 2013
2,867
Well I am an avid sponsor of the Darwin awards and I do encourage as many people as possible to participate the best of their ability......;)
Did you really expect anything less from a crazy green haired clown in a straight jacket? :D
ElectromagnetNewbee
Joined Jul 13, 2014
69
Granted as mentioned you may only have 15 amps per circuit to work with but at twice the voltage your line voltage drops will be far less of an issue if you are trying to pull 2+ KW off of a 240 VAC feed systems VS a 120 VAC single feed.
If you are planning to cheat as much as you can to get as much power as possible then I would suggest doubling up on the 15 amp 120 VAC lines on each half of the 240 VAC feeder you are making.
Doing that you could in theory allow you to pull ~6 KW without overloading any single circuit or wire line set or modifying a single electrical circuit in your apartment. Everything would be handled by extension cords going to a central 240 volt source point.
You are right in line with me amigo! :) thanks and much love for the info.
