Need 7 and 9 megaohm resistors, where to get?
ScottCT
Joined Feb 17, 2009
3
For a Heathkit VTVM, need 1% resistors at least 1/2 watt, 7 and 9 megaohms.
Any idea where to get them, Mouser and Digikey no have.
TY
Scott
strantor
Joined Oct 3, 2010
6,791
TY
Scott
Why do you need at least half watt?
It would take at least 2,100V to dissipate 1/2W into a 9Mohm resistor.
It would take at least 2,100V to dissipate 1/2W into a 9Mohm resistor.{/quote]
With a 1000 V input (guessing) and a 2x safety factor, that isn't to bad.
I had to buy a 1 Meg 200 W resistor once and on the other side of the scale a 0.5 ohm adjustable resistor rated at 1000 W and I did buy a few 400 M resistor onec.
ScottCT
Joined Feb 17, 2009
3
The 7 and 9 megaohm are part of the main voltage divider reference. The existing ones have drifted a little high, which throws off
voltage readings. Ohmcraft might be a possibility if they will sell one off. TY Keepitsimple
JohnInTX
Joined Jun 26, 2012
4,787
Here's a search at Mouser that gets pretty close. 9.09M 1/2 Watt, 6.81M .4W, in stock. Monkey around with the filters for other close ones. Lots more 1/8Watts. Maybe parallel a couple. Vishay is a good go-to for things like this.
