Need 12v dc in to 9v dc out isolated DC Converters
N11778
Joined Dec 4, 2015
176
Low cost, Small, 10ma output, 12v to 16v dc in.
I want to use Harbor Freights free Meter for numerous applications.
Did I just hear a Chick, or was that the sound of the word Cheep.
Mostly for prototyping new Projects.
Thanks for any ideas.
WBahn
Joined Mar 31, 2012
33,340
How about 9 V batteries? At 10 mA, they will last quite some time, probably 40 to 50 hours of use.
What does using a Harbor Freight meter have to do with the question?
Are you trying power these meters from an external source?
mcgyvr
Joined Oct 15, 2009
5,394
Define "low cost"
Define "small"
Have you ever used the search/filter functionality on electronic component site suppliers like Digikey, Farnell/Newark , Mouser,etc...?
BobaMosfet
Joined Jul 1, 2009
2,211
Yes. and they will be on for years during testing.
Yes, I get most of my stuff from Digikey Most EBAY stuff is from China
Why don't you just use a AC->DC 9V Wallwart?
Don't knock China, they have a lot of incredible vendors there that sell quality stuff that you can't even get in this country. And it isn't junk.
ebeowulf17
Joined Aug 12, 2014
3,307
Do the meters you plan to use have an auto power off function? Every meter I've used in the last twenty years or so has had that function. If yours do, then they won't be on for years during testing!
RichardO
Joined May 4, 2013
2,270
Thanks Will Breadboard it and try.
A couple of comments...
First, the circuit was designed for 5 volts in. If you use 12 volts, the output voltage is probably too high for your typical meter. It may even damage it.
Second. If you use a CMOS 555 timer, I think it can power several meters. The meter I tested drew way less than 1 mA. Keep in mind that you need one copy of the circuit per meter otherwise the measurements will interact.
N11778
Joined Dec 4, 2015
176
Thought of that too. Should be able to drop it to 9v with a resistor divider.
Should be able to Drive 5 Ckts with one 555 chip.
Need 5 meters.
Thanks again
RichardO
Joined May 4, 2013
2,270
Need 5 meters.
Thanks again
In general, using voltage dividers in power circuits does not work well. The problem is that the load is not well known or it varies.
I would use an LM78L5 voltage regulator to get a solid 5 volts for the meter circuit.
RichardO
Joined May 4, 2013
2,270
How about a 9v zener the battery in the meter is 9v
That and a 4.7K ohm current limiting resistor. It would be a bit of a pain to do it in every meter, though.
A single 5.1 volt Zener and 680 ohm current limiting resistor would work for making 5 volts for the CMOS 555 circuit. But, I still prefer an LM78L05.
p.s. Don't forget power supply bypassing for the 555.
N11778
Joined Dec 4, 2015
176
Well, test results were not so good.
See attached Diagram of the actual ckt.
I never thought of using one of them, I have many in the junk pile.
It did not work either, the meter reading was very erratic jumping from 15v to 0v testing the battery.
Looks like I will stick with the batteries.
I'm in a very noisy environment 8 modified sign-wave inverters come on alone or together at various times.
don't know if that's it but it could be why the AC->DC converter did not work.
BTW, I was using power off the Grid to power the converter not the Modified sign-wave power.
38,938
Re: Using a wallwart.
What kind did you use?
Did it put out a regulated 9Vdc?
N11778
Joined Dec 4, 2015
176
Re: Using a wallwart.What kind did you use?
Transformer type, Not regulated, 9v DC, it put out 15v DC.
I regulated it at 9 volts with a resistor and zener diode at the meter.
I also hooked it to two different bench power supply's, same results with both supply's.
BobaMosfet
Joined Jul 1, 2009
2,211
I'm inclined to say you're mis-using the wallwart, or it's defective. All such devices (in fact, any device that provides power) is designed to provide a regulated voltage within a range, based on an expected load or range of loads. A meter doesn't provide sufficient load.
Likely your 9V wallwart is just fine.
However, what would really be nice is if you told us a model number, or provided a link to this 'meter' you're referring to from HF, so we could look at it, and obtain specifications. It could be that you're completely misusing it.... just a thought.
