- Oh, I didnt lie when I said I got this lamp along with other components in a big box from an old timer. I was trying to identify this lamp by remembering very vaguely that I seen it in some vintage portable flash lights for photography when I was little and my dad was a young gentlemen and was doing photography. He is a bigger artist than me. He still makes random photos today but with a digital camera, and is doing it constantly without discern. Haha. The thing is, he likes it or better say, he still likes it. Which is a phenomenon in itself and I respect him for that. He is very old now, he's 78.If you want to experiment with these Xenon flash tubes, see if you can find the disposable film cameras where you live.
So that gray metallic marking inside one of its leg is a sign of usage. But not burned. Right?The lamp is probably a tired old dog.
Hmm. I guess in 8 years I will be very old, does that mean I will have to stop:He is very old now, he's 78.
My post wasn’t meant to be serious, just a humorous take on how different the perspective can be on being old.to mister @BobTPH , no disrespect intended. Im just stating the facts that my father is indeed on its last years. I know it, he knows it, and is nothing wrong with it, aside feeling bad about it. I certainly do feel bad. Especially in my artist ycondition. And if it is somewhat cooling you down from depression, ---I--- feel VERY old and im 42. And Im fine being old, or told to be old, that means I have a lot of experience and I am very wise in some elements from my life. Im stupid also with my life as a whole, I know it but thats the cards I was deal with and nothing can change it, well, except you know what. Hahaha. Thats most probably why I lough so much.
Thank you. Can it be turn into a continuous light? If I strobe it really quickly?It's a strobe, with the rate set by the pot (dimmer).
I had to switch a couple of components around after finishing it.
But it still didnt work.
I mean... I strongly believe the circuit is working , at least this part of the circuit is working fine:
How Im so sure? Because, AFTER I take it out from the mains, disconnect it totally from power, I put my large tweezers over the 2 pins of the lamp to discharge whatever charge is accumulated. And I had to turn around a couple of capacitors to actually fit them with the correct polarity. By the way, the case is (+) and the isolated pin is the (-) of the capacitor. They are made in romania, a long time ago when everyone was making it's own rule. Romanians were in the front of inventing new rules. Haha. So, after I switched a couple of times the capacitors around, put it in power, disconecting and discharge the rails, I got different results, different sparks, sometimes no spark at all, the 10W resistor was boiling in some circumstances, so by trial and error, also the sparks helped me evaluating the final placement and polarity of the caps, I got it right in the end. Why Im so sure? Because now I get a healthy spark on the rails, and also the markings of the caps are oriented to the correct pads in the circuit. It was a pain in the but I manage it. Im not so sure about the middle circuit though.... I couldn't test it properly. Instead of the 1M pot I put a 330k fixed resistor. That should have give me plenty of flashes in my opinion. Im thinking maybe the triac is burned? I didnt test it. I trust it because I usually store good components and I test them before I store. I dont remember this one in particular though.... Hmmm It may be its fault.
All this IF the circuit is wrong. BUT if the circuit is good... then the only problem remains the bulb being burned!
And I discovered now when all the circuit board is finished, that is a small metal piece that is traveling INSIDE the glass tube when I rotate it. So... I start to believe that is a piece of the electrode... hahahahaha. and this thing is really burned. Just look at that black thing it has on top pin.
My conclusion: - I believe I made a good test circuit here, even if the lamp didnt work. I strongly believe the lamp is busted. So mission accomplished. Very hard to build the actual circuit. Eh well. I push it and now is done.
Thank you very much for all your support so far.
It was somewhat fun.
I was thinking to ask you, if I can truly test or measure this circuit output somehow, just to confirm (to myself) that it is good indeed. With some other thing than this bulb. With a protection resistor and a led maybe? Or something that will give me some sort of feedback. You get it.
