MaxHeadRoom
- Joined Jul 18, 2013
- 30,808
Not that way… A variac only works with AC. DC after the rectifier won’t work with a variac. You could put the variac BEFORE the rectifier and filter (you need a hefty capacitor in addition to a bridge rectifier).I can use my variac to slowly and gradually rise up the rectified voltage after a rectifying bridge. Just a thought.
OR
a circuit for a blitz ? I searched myself for one but I didnt get anything useful from google.
What I meant was the AC variac then a rectifying bridge to obtain a DC current to power the lamp. I went too overzealous in explanation there. My bad.q12x said:
Those trigger coils are used to get the voltage high enough to flash the lamp. You’re already starting with a high voltage. You also need current and the capacitor supplies that.
Now im reading your recommended page.Here is an example of one circuit, tells how to make the trigger pulse transformer.
https://www.homemade-circuits.com/mains-ac-xenon-tube-flasher-circuit/
Excellent find !!! Thank you.A Google of "Xenon flash tube circuits" will bring up dozens of examples of flash tube circuits including images of what you have. Next a Google of Xenon flash tube trigger transformers will bring up plenty of 4 to 10 KV trigger transformers. Xenon flash tubes like the one you have typically retail for about $3.50 USD.
Mister @MaxHeadRoom, I'm building your recommended circuit.Here is an example of one circuit, tells how to make the trigger pulse transformer.
