My teacher gave us a question that doesn't seem to make any sense
tmerchant
Joined Aug 7, 2017
It makes perfect sense. How much power has to be consumed to give you the 5VRMS drop? Simple E=IR stuff.
But he doesn't give a load resistance so how am I supposed to calculate the total current? Obviously if it was just the wires in the street then I could do 5 / 0.2 to get 25 amps but he's implying there is a third component which are the wires inside the house which are also dropping part of the voltage so now it becomes 5 / (0.2 + R). And surely that requires some other bit of information such as the load.
Perhaps I am misreading the question and he actually does just want me to do 5 / 0.2 but that seems to easy.
SLK001
Joined Nov 29, 2011
1,549
What do you mean by "He doesn't give a load resistance"? It's right there in the problem - 0.2Ω. What current through the 0.2Ω resistor will give you a voltage drop of 5VRMS? Now, what is the power that will draw that current (P=I⋅V)?
Everything is there - just figure it out. 25Amps is the current. What is the power?
WBahn
Joined Mar 31, 2012
32,783
My teacher doesn't say how much power is being drawn by the device plugged in therefore this question doesn't seem answerable to me.
Does this question make sense to any of you?
Sorry for the stupid question.
Do the first part of the problem. Sketch the circuit including all of the values noted. For the load resistance, just put a resistor and call it's value "Rload".
Doing that will probably give you the hint you need to solve the problem asked without needing to know Rload.
tmerchant
Joined Aug 7, 2017
I did that, I'm 100% sure I misinterpreted the question. I understand now, it was just unclear wording to me.
