My first SMT stencil
cmartinez
Joined Jan 17, 2007
8,864
Thanks for sharing!! I haven't tried stencils yet, but have found HP Premium Presentation paper works good for PCBs. I does leave fibers behind that need to soak to get them to rub off between traces, but otherwise I've never had a problem due to the paper itself.
I stopped using presentation paper eons ago... now I use the backing paper of commercial vinyl film.
Check this post.
cmartinez
Joined Jan 17, 2007
8,864
Update.
I've just discovered that placing the glass container with a mixture of 50-50 muriatic acid and peroxide under the heat (177°C / 350°F) of my heat press very significantly accelerates the process and also results in a much finer and higher resolution etch.
bfcc4fde-0cff-43e2-b637-5fd05387f240.jpg​
This recent discovery is definitely a keeper.
