nerdegutta
- Joined Dec 15, 2009
- 2,684
UV and etchant.Do you have a CNC machine? What kind? or are you just going to use etchant??
I see the text is really small. That could be an issue for me...
Well... I guess it has. Or at least I can set the Drill sizes. To make bigger pads, I think you must edit the footprint.Does eagle have a hole-size editor. Many of the hole sizes are not optimal for DIY boards. And some of the pads could have been larger. You need as much copper as possible. As an anchor to the board. Since your board is not plated
Thanks. Took about 30 minutes from printout to complete etched.Nice job, looks almost perfect apart from the dots which don't make any difference.
How is your ironing going, by the wayJens send it...I need to test my circuit and the programing...
How much do I owe you ? For the shipping that is
I left a stain or burned mark on the bedsheets and it went all the way to the mattress..How is your ironing going, by the way
Ok so in the process of making a PCB you burned your bedsheets, and your mattress. I think I understand. No on second thought I do NOT understand at all. And will not even try to understand. Why do you not free some space on your workbench for this kind of work The best thing is perhaps to continue the use of Nerdeguttas PCB service. Tell me if the service and quality is good. I might through in some orders my self.I left a stain or burned mark on the bedsheets and it went all the way to the mattress.. I am now officially a criminal.... I cannot explain to wife.. by the way that board has thru holes and SMD's
Ur not Wookie ...( I know u wouldn't get what I mean)Ok so in the process of making a PCB you burned your bedsheets, and your mattress. I think I understand. No on second thought I do NOT understand at all. And will not even try to understand. Why do you not free some space on your workbench for this kind of work The best thing is perhaps to continue the use of Nerdeguttas PCB service. Tell me if the service and quality is good. I might through in some orders my self.
Yes it does. Nerd is not even close.I think the term you are looking for is a US Marine. That outcools nerd.
No, I'm not a Marine.Umm..jens, are u a Marine by any chance?
