My BC547 is getting very hot
pprmz89
Joined May 28, 2018
Hi. I made very simple audio amplifier with circuit from youtube video. The amplifier work very well for me, but after some time the transistor BC547 is getting so hot. And even it failed to work. I saw this treat here:
https://forum.allaboutcircuits.com/...t-where-should-i-be-putting-a-resistor.24714/
and I think I must use resistor to cool my transistor, but my circuit is different then the @samoz's circuit.
Please tell me what to do.
Thanks in advance.
Moderators note : copied image to forum
ArakelTheDragon
Joined Nov 18, 2016
1,366
and I think I must use resistor to cool my transistor, but my circuit is different then the @samoz's circuit. Please tell me what to do. Thanks in advance.
The circuit is missing. You need a heat sink. Even if it is a 5W amplifier you still need a heatsink. The resistor is in order to stabilize the current.
DickCappels
Joined Aug 21, 2008
10,661
That circuit is trying to put hundreds of milliamps through the collector when the maximum rated collector current is only 100 milliamps.
Put about 15 Ohms in series with the speaker, change the 1K to 10k, put a 1.8k resistor from the base to ground, and put a 1k resistor in series with the input capacitor. That should lower your collector current to something like 30 milliamps average and power dissipation to a little over 100 milliwatts. It won't be as loud as it was before but the transistor is much less likely to burn.
It is highly recommended that after you see this work you get back on the internet and look for a better amplifier or even build one around the LM380 audio amplifier IC. It is very likely that you will receive more suggestions in this thread.
Apologies to @Audioguru for wrecking the speaker damping if there was much to start with.
Alec_t
Joined Sep 17, 2013
15,125
A BC547 is totally unsuitable for that post #1 circuit. It is rated at ~0.5W, but in your circuit it will be dissipating about 1.2W. No wonder it gets hot :eek:.
AlbertHall
Joined Jun 4, 2014
12,636
Your single transistor speaker amplifier is called a "Class-A" amplifier. The transistor is biased in the active region and is always on and conducts a lot of current. This is very inefficient and why it is getting hot.
Try a Class-B amplifier or Class-AB instead, something like this:
http://www.deeptronic.com/electronic-circuit-design/small-audio-power-amplifier-using-3-transistors/
If the intention is to experiment with making an amplifier then that's OK.
If the intention is to make an amplifier then how about the LM386?
pprmz89
Joined May 28, 2018
Nice suggestions. Thank you very much.
@MrChips, your circuit sims very interesting, but how to add second speaker?
Also I'm looking for circuit that works with 2 8ohms 10 watts speakers. Can you suggest something? Thanks in advance.
ArakelTheDragon
Joined Nov 18, 2016
1,366
I am glad to hear, you need 2x10w and not 2x1000, when someone tells me he has a 1000W speaker and amplifier in his car and it works 5hours without draining the battery at all, while the car is not running, I tell him the nuclear powerplant is working for him.
You already got a suggestion using LM380 or LM386. You can also try tda2050 but I have not tested it and I do not know how good it is.
34,908
Where, why and how do you want to add a second speaker?
Do you want to add the second speaker in series or in parallel with the first on the same amplifier output?
Or do you want to create a second audio channel for stereo?
10W is substantially more than what has been presented so far. You need to tell us your complete objectives of this project.
pprmz89
Joined May 28, 2018
First I thought to add second speaker to this amplifier, but now I'm looking for circuit to make amplifier with TDA2050. My idea (for now) is to make 2 amplifiers(one for left and ane for right) with TDA2050 and to connect to them one speaker, and add double potentiometer for volume control.
ebp
Joined Feb 8, 2018
2,332
You cannot drive a single speaker with two separate amplifiers unless the amplifiers have a common input signal, and even then it is generally a bad thing to do. A slight imbalance in the phase shift caused by the input coupling capacitor and terminating resistor could cause one amp's output to be at a different voltage than the other, resulting in high current between the amp's outputs. If you have a stereo source and want just one speaker, then you can mix the two channels before they are applied to the input of a single amplifier.
34,908
Do make up your mind. Do you want mono channel or dual channel (for stereo)?
As ebp says, if you add two channels into one speaker (for more output power) you could end up blowing your amps.
Doing the above is not recommended.
If you want more power into a single speaker, you can bridge the outputs of the amp into one speaker if you invert the signal going into one of the amps.
The two amps are driving the speaker with 180° phase difference.
Audioguru
Joined Dec 20, 2007
11,248
You do not increase the power to one speaker with amplifiers in parallel.
Pick a modern amplifier IC. The TDA2050 is obsolete and is not made anymore.
If you want to convert stereo to mono then you need a mixer circuit, not just shorting the source channels together.
ArakelTheDragon
Joined Nov 18, 2016
1,366
A lot of things are not made anymore, but we still use them.
And yes putting the 2 cables on 1 input with 2 resistors is enough.
