BC547 overheating
haroontheengineer
Joined May 29, 2022
10
Hi guys! I'm trying to make a relay module to control appliances using NodeMCU but the problem I'm facing is overheating of the transistor and it stops working. Your help will be appreciated.
Image of my circuit is attached.
ag-123
Joined Apr 28, 2017
294
use a multimeter and measure the Vce voltage across BC547 when it is turned on, if it is rather high like closer or > 1 v, much higher currents is passing in the transistor. An 'easy' solution is to place a resistor like 10 ohms at the emitter.
bertus
Joined Apr 5, 2008
22,989
As said, you need a suppression diode.
What is the output voltage of the MCU?
If it is lower as the mentioned 3.3 Volts, you might need to reduce the value of the 500 Ohms resistor.
Bertus
haroontheengineer
Joined May 29, 2022
10
I have replaced the transistor. Now the transistor sometimes switches on but the base current remains the same even though the transistor doesn't work i.e. almost 5 mA. Is this a transistor issue?
ericgibbs
Joined Jan 29, 2010
21,532
hi har,
The Gain of the BC547 is approx 100 at 100mA, so 5mA should switch On the transistor.
Can you post a photo of the layout of your circuit so that we can check the connections.?
E
Papabravo
Joined Feb 24, 2006
22,105
I estimate the power dissipation in the on state to be about 8 mW. The only thing that could cause heating of the magnitude that you are observing is an error of some type.
