Probably your curve is correct. I have found this in the datasheet:I cite my research amp LTspice system.
Have you ever done it? are you sure? can you post any schematic of all things about your idea?Another way you can go about boosting an electret mic with a bipolar transistor; use the grounded base configuration.
Picture the classic textbook common emitter stage, both collector and emitter have a resistor to their respective supply rail, and the base is fed by a potential divider across the rails.
The bit that changes it from common emitter to common base, is simply moving the bypass capacitor from the emitter resistor to the lower resistor in the base divider.
The first thing to do is look up the recommended voltage for the electret capsule - its usually about 2V. The B/E junction will drop about 0.7V, so the voltage divider should be set to feed the base; 2.0V + 0.7V = 2.7V - now; simply replace the emitter resistor with the electret capsule.
If you can get hold of the exact right data sheet for your electret capsule, it should tell you the current for it, if not most are similar so any data sheet will give you somewhere in the right direction. If you can't get the spec for current, replace the collector resistor with a 100k pot and adjust for best operating point.
The common base configuration will give you plenty of voltage gain, but the current gain will be a tiny bit less than 1 - an emitter follower hung on the output will soon sort that out.
