[Multisim] Transient time point calculation did not converge
xxxyyyba
Joined Aug 7, 2012
289
Hi. I have problem simulating this circuit in Multisim:
(LTSpice)
Here is scheme from Multisim:
When I run transient analysis, I got this:
------ Checking SPICE netlist for Design3 - Saturday, September 26, 2015, 10:58:03 AM ------
======= SPICE Netlist check completed, 0 error(s), 0 warning(s) =======
Simulation canceled
Any idea what's wrong? Thanks in advance
xxxyyyba
Joined Aug 7, 2012
289
And with previous version I didn't have problems simulating circuits with opamps. I think this problem has something with opamp power supplies, if I remove them, simulation starts without error. But opamp must have power supply to work :)
Alec_t
Joined Sep 17, 2013
15,119
Maybe your new software version is more picky about unconnected pins? Wouldn't hurt to add the offset null pot and compensation cap as per the datasheet. Convergence problems often need only a trivial adjustment of a circuit parameter to overcome them.
xxxyyyba
Joined Aug 7, 2012
289
I get same error on Multisim 13.0.1 Power Pro. There is something wrong with this model of op amp in both versions of Multisim I tried. :confused:
DerStrom8
Joined Feb 20, 2011
2,390
Usually convergence issues are caused by shorts (I think?). Try adding small resistors (1 milliohm) in series with the power supplies. If I remember right, Multisim does not like "backwards" power supplies (used for the negative voltage supply).
xxxyyyba
Joined Aug 7, 2012
289
@DerStrom8,
I added 1 miliohm resistors in series with opamp power supplies and simulation starts without error. However, output voltage waveform doesn't look as it should. But I think we are close to solution :)
